iOS app broken
After updating from 4.100 to 4.110 I am no longer able to log inn to the iOS app. I have logged inn to Fibaro Home and changed the password but that didn't help either.
12 answers to this question
Guest chaicka
Works fine here on iPhone 6s and iPad Pro.
    Since this is the first time since I installed the iOS app that it has not worked I didn't remember that I also need to enter the HC2 login info in addition to the Fibaro Home login info. It now works.
    Edited by Ole
    My mistake
    Can you tell what did you done to make it work ?
    I cannot still connect my iPhone back to HC2 :(
    Just go to Choose HC in the app, choose edit and enter the e-mail address you now use for your login and your password.
    Edited by Ole
    " to "
    Temat został przeniesiony z "
    " do "
    I have another problem though. I recently got the iPhone 7, but I am not getting push notifications. It works fine on the iPad Mini 2, my old iPhone 5S and my wife's iPhone 6S.
    Anyone have the same problem?
    This hasn't made my iPhone app work.  It did on the iPad.
    And now both my iPad and iPhone are broken.  Neither of them will connect remotely.
    The iPhone works when at home on the LAN, but the iPad doesn't even do that.
    Something is amiss in remote access/iOS app land!
    Just an update for the iPhone and iPad apps come through.
    iPad is now working remotely.  Just waiting for the iPhone to update...
    iPhone working too.
    Still not getting push notifications on my iPhone 7.
    Yes, it works!
    Edited by Ole
    Works again
