I am having two doubts.
1) How many devices can be connected with a Home centre 2.?
2) How can i connect fibaro devices for a Multi Storey building?
Hope someone will give me reply
4 answers to this question
I live in a 3 story town house with the HCL in the garage and have no issue with device connectivity. The Z-wave network range grows as you add mains powered devices, hope this helps!
Permanently powered devicess (your wall plugs, relays, dimmers, universal module, etc.) are relaying signal, so if you place your unit well enough than you might not need to buy additionall HCLs*.
There is the 4 hop limitation offcourse so it might take some finese in planning to get it right.
*this statement pressumes that your house is not made of particullary thick or metalic materials (metal floors, tin cealings, metal coated wallpapers etc.).
Guest chaicka
Multi-Storey...3? 4? 5?
Inter-Storey is reinforced concrete slabs?
