Sonos Play Fil VD issues
Hi all.
I have install this Sonos VD to play MP3's at a click of a button.
Short files work fine like sound effects but full music tracks only play for about 20 seconds.
Can anyone help with this.
I have attached the LUA below so you can see what I am using. All you have to do is change the last line to where your MP3 is and the required volume and that's it.
Look forward to the reply.
Andy
-- SONOS Play stream...
-- Copyright © 2014 Jean-Christophe Vermandé
selfId = fibaro:getSelfId();
ip = fibaro:get(selfId, 'IPAddress');
port = fibaro:get(selfId, 'TCPPort') or 1400;
currentTransportState = "";
lastTransportState = "";
currentVolume = 0;
lastVolume = 0;
ttsVolumeIsDifferent = false;
urlencode = function(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n");
    str = string.gsub (str, "([^%w ])", function (c) return string.format ("%%%02X", string.byte(c)) end);
    str = string.gsub (str, " ", "+");
  return str;
createRequestBody = function(action, schema, data)
  return string.format("<u:%s xmlns:u=\"%s\">%s</u:%s>", action, schema, data, action);
reponseCallback = function(fnc, args)
  if (fnc == nil) then
    return nil;
  return fnc(args);
createSocket = function()
    -- Check IP and PORT before
  if (ip == nil or port == nil) then
    fibaro:debug("You must configure IPAddress and TCPPort first");
    return;
  local socket;
  local status, err = pcall(function()
      socket = Net.FTcpSocket(ip, port);
      socket:setReadTimeout(1000);
    end);
  if (status ~= nil and status ~= true) then
    fibaro:debug("socket status: " .. tostring(status or ''));
  if (err ~= nil) then
    fibaro:debug("socket err: " .. tostring(err or ''));
    return;
  return socket;
disposeSocket = function(socket)
  if (socket ~= nil) then
    socket:disconnect();
    socket = nil;
    return true;
  return false;
sendSoapMessage = function(url, service, action, args, callback, retry)
  local socket = createSocket();
  if (socket == nil) then
    return;
  retry = retry or 0
  -- prepare data
  local url = "POST " .. url .. " HTTP/1.1";
  local soapaction = "SOAPACTION: \"" .. service .. "#" .. action.name .. "\"";
  local body = createRequestBody(action.name, action.service, tostring(args or ""));
  local envelope = "<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body>" .. body .. "</s:Body></s:Envelope>";
  local ctl = "Content-Length: " .. string.len(envelope);
  local payload = url .. "\r\n" .. ctl .. "\r\n" .. soapaction .. "\r\n" .. "\r\n" .. envelope;
  -- write data
  local bytes, errorcode = socket:write(payload);
  if (errorcode == 0) then
    local state, errorcode = socket:read();
      if (string.len(state or "") > 0) then
        -- callback
        if (callback ~= nil) then
          reponseCallback(callback, state);
        -- dispose ...
        disposeSocket(socket);
        return true;
      else
        fibaro:debug("Error: Invalid response. response length: " .. string.len(state or ""));
    else
      if (retry < 5) then
        fibaro:debug("retry #"..retry.." action: " .. action.name);
        return sendSoapMessage(url, service, action, args, callback, (retry + 1));
      else
        fibaro:debug("Error: Code returned "..tostring(errorcode or ""));
  elseif (errorcode == 2) then
    fibaro:debug("Error: You must check your IP and PORT settings.");
  else
    if (retry < 5) then
    else
  -- dispose ...
  -- default response
  return false;
stop = function()
    -- control url
    "/MediaRenderer/AVTransport/Control",
    -- service type
    "urn:schemas-upnp-org:service:AVTransport:1",
    -- action
    { name = "Stop", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    -- soap body data (options)
    "<InstanceID>0</InstanceID><Speed>1</Speed>",
      -- callback (options)
    function(response)
      fibaro:debug("stop sent");
    end);
unMute = function()
    -- control url
    "/MediaRenderer/RenderingControl/Control",
    -- service type
    "urn:schemas-upnp-org:service:RenderingControl:1",
    -- action
    { name = "SetMute", service = "urn:schemas-upnp-org:service:RenderingControl:1" },
    "<InstanceID>0</InstanceID><Channel>Master</Channel><DesiredMute>0</DesiredMute>",
    function(response)
      fibaro:debug("unMute sent");
    end);
play = function(duration)
    -- control url
    -- service type
    -- action
    { name = "Play", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    function(response)
      if (duration ~= nil) then
        fibaro:debug("play sent for " .. duration .. " seconds");
        fibaro:sleep(duration);
        stop();
      else
        fibaro:debug("play sent");
        local n = 0;
        currentTransportState = "TRANSITIONING";
        while (currentTransportState == "TRANSITIONING") do
          if (n > 10) then break end;
          getTransportState();
          fibaro:debug(currentTransportState);
          fibaro:sleep(5000);
          n = n + 1;
        local i = 0;
        currentTransportState = "PLAYING";
        while (currentTransportState == "PLAYING") do
          if (i > 10) then break end;
          fibaro:sleep(2000);
          i = i + 1;
        fibaro:sleep(1000);
        stop();
      -- update volume with value before tts if different
      if (ttsVolumeIsDifferent == true) then
        setVolume(lastVolume);
    end);
setVolume = function(value)
    -- control url
    -- service type
    -- action
    { name = "SetVolume", service = "urn:schemas-upnp-org:service:RenderingControl:1" },
    "<InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>" .. tostring(value) .. "</DesiredVolume>",
    function(response)
      fibaro:debug("Volume set: " .. value);
    end);
getVolume = function()
  fibaro:log("Get volume, please wait...");
    -- control url
    -- service type
    -- action
    { name = "GetVolume", service = "urn:schemas-upnp-org:service:RenderingControl:1" },
    "<InstanceID>0</InstanceID><Channel>Master</Channel>",
    function(response)
      currentVolume = tonumber(response:match("<CurrentVolume>(.+)</CurrentVolume>") or 0);
    end);
getTransportState = function()
    -- control url
    -- service type
    -- action
    { name = "GetTransportInfo", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    "<InstanceID>0</InstanceID>",
    function(response)
      currentTransportState = response:match("<CurrentTransportState>(.+)</CurrentTransportState>") or "";
    end);
playFile= function(file, volume)
-- control url
-- service type
-- action
{ name = "SetAVTransportURI", service = "urn:schemas-upnp-org:service:AVTransport:1" },
"<InstanceID>0</InstanceID>,<CurrentURI>x-file-cifs:" .. file .. "</CurrentURI>,<CurrentURIMetaData></CurrentURIMetaData>",
function(response)
-- retrieve current transport state
lastTransportState = currentTransportState;
-- unmute before
unMute();
-- retrieve volume
getVolume();
lastVolume = currentVolume;
-- set tts volume if <> with current
if (volume ~= nil and volume ~= currentVolume) then
setVolume(volume);
ttsVolumeIsDifferent = true;
play();
end);
playFile("//192.168.1.247/Music/Incoming.mp3", 70);
I'm no programmer but I had the same problem.... I messed with the code and did this.... seems to work...
currentVolume = 0;
lastVolume = 0;
  if (str) then
  return str;
    return nil;
  return fnc(args);
    return;
  local socket;
    end);
    return;
  return socket;
    socket = nil;
    return true;
  return false;
    return;
  retry = retry or 0
  -- prepare data
  -- write data
        -- callback
        -- dispose ...
        return true;
      else
    else
      if (retry < 5) then
      else
  else
    if (retry < 5) then
    else
  -- dispose ...
  -- default response
  return false;
unMute = function()
    -- control url
    -- service type
    -- action
    function(response)
    end);
    -- control url
    -- service type
    -- action
    function(response)
        stop();
        fibaro:sleep(1000);
    end);
    -- control url
    -- service type
    -- action
    function(response)
    end);
    -- control url
    -- service type
    -- action
    function(response)
    end);
    -- control url
    -- service type
    -- action
    function(response)
    end);
    -- control url
    -- service type
    -- action
    function(response)
      -- unmute before
      unMute();
      -- retrieve volume
      getVolume();
        setVolume(volume);
      play();
    end);
-- parameters: the file, the volume
playFile("//192.168.1.1/sounds/ti.m4a", 20);
Hi could someone help me please with this VD, I use the above code but I hear no sound.
This is the path to my MP3 file:
playFile("//192.168.1.251/Users/Thijs/MP3/Burglar-alarm-sound.mp3", 40);
DEBUG
