Reintjan 29
Recently I bought a Homecenter Lite and I'm experimenting with scenes. Now I discovered something I believe is a bug in Fibaro scenes. Hope you can confirm or tell me what I'm doing wrong here.
First, let me explain how I work:
I have some lights outside which I want to switch on and off depending on the time of the day with different timestamps depending on the day of the week. Also I use a variable "daypart" (dagdeel in Dutch) which switches in scenes from morning to afternoon to evening depending on the time of the day. The variable "daypart" is set to night in the scene which switches of the lights late in the evening. Now in the morning, at exact time 07:00 I have a scene which checks if "daypart" is still night (it will switch in another scene to morning at sunrise) and if so it switches the lights outside to on.
Now the problem, the last scene described should check if time is exact 07:00 and then check if daypart is still night. Only if that's the case it should switch on the lights. Now, what's really happening, when my scene which switches off the lights late in the evening and sets daypart to night (mostly around 23.30) the lights switch to on again after 4 seconds. The lights only stay off if I disable the scene which should only work at 07:00.
Now, anyone knows what's going wrong here? I suppose the scene is triggered only by change of the variable instead of variable combined with exact time as stated in the scene.
See also both scenes as sample
Edited by Reintjan5 answers to this question
