Patrick 11
All,
I want to share, what looks like a simple usecase BUT still very complex to build or find the right settings within the (fibaro) Dimmer2 or in combination with a scene.
Used (involved) Components: 1x Dimmer2 (FGD212), 1X Lamp, 1X HC2 (v4110)
Description of the use case:
When I turn on the light (manually) after SunSet the dimmer is set to 20% else will be 80% or a double-click will set the light to 100%. (last part is simple as this is a functionality is within the dimmer it self)
(I do not want a bright light when I go to the loo in the middel of the night)
Interested in any suggestions
