Help needed to access heating system
I could use some guidance with trying to access my heating system.
I can access the controller locally through a website and the website is sending following to the controller e.g.
To read all the data from one room
/api
POST /api HTTP/1.1
Host: xxx.xxx.x.xx
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.11; rv:50.0) Gecko/20100101 Firefox/50.0
Accept: application/json, text/javascript, */*; q=0.01
Accept-Language: nl,en-US;q=0.7,en;q=0.3
Accept-Encoding: gzip, deflate
Content-Type: application/json; charset=utf-8
X-Requested-With: XMLHttpRequest
Referer:
Content-Length: 697
Connection: keep-alive
{"jsonrpc":"2.0","id":10,"method":"read","params":{"objects":[{"id":"20","properties":{"85":{}}},{"id":"21","properties":{"85":{}}},{"id":"22","properties":{"85":{}}},{"id":"23","properties":{"85":{}}},{"id":"24","properties":{"85":{}}},{"id":"26","properties":{"85":{}}},{"id":"27","properties":{"85":{}}},{"id":"29","properties":{"85":{}}},{"id":"30","properties":{"85":{}}},{"id":"37","properties":{"85":{}}},{"id":"39","properties":{"85":{}}},{"id":"62","properties":{"85":{}}},{"id":"67","properties":{"85":{}}},{"id":"70","properties":{"85":{}}},{"id":"92","properties":{"85":{}}},{"id":"132","properties":{"85":{}}},{"id":"172","properties":{"85":{}}},{"id":"212","properties":{"85":{}}}]}}
HTTP/1.1 200 OK
Content-Length: 883
To change the set point of a room :
POST /api HTTP/1.1
Host: xxx.xxx.x.xx
Referer:
Content-Length: 114
{"jsonrpc":"2.0","id":14,"method":"write","params":{"objects":[{"id":"91","properties":{"85":{"value":"19.5"}}}]}}
HTTP/1.1 200 OK
Content-Length: 40
What i would like to do is :
1.  get data from the heating controller into HC2 and make them visible in a VD
2.  change e.g. setpoints in the VD and write them back to the heating controller.
at this moment i have no idea if this is possible and if yes, how to do it.
hopefully someone can point me in the right direction.
thanks
Edited by WimF
Guest reiniertc
I'm looking for exactly the same, except in my case to control my Bravia TV
