1 minute ago, FredrikKarlsson said:
I agree. But, please realize that what we are discussing here is only the ability connect to your home effortlessly. Not the ability to have home automation.
If you need to connect from afar to manually set something up regularly, then maybe you don't have enough home automation set up ;-) and are forgetful.
Basically, I just felt the need to point out that if you need external access and go though a cloud service, then you will be open to being dragged into a situation when Fibaro is hacked. This was true in the previous remote access system fibaro used, and it is still true for connecting through the new system.
Fair enough point.
Hand i poses home automation outsside work i would likely want to have some way to turning things off because i am forgetfull person.
