I need your help guys;)
I want to display the data from YT in vd: the amount of views on a particular channel and the total number of videos
I have a direct link that displays information in JSON:
If I put it in web browser, I see the following information:
// 20170117085953
{CHANNEL_ID}&key={MY_API_KEY}
  "kind": "youtube#channelListResponse",
  "etag": "\"gMxXHe-zin558lTnzKu8vjcmDI/2Qud556x4kgLe-969qH7-65gh7t\"",
  "pageInfo": {
    "totalResults": 1,
    "resultsPerPage": 1
  "items": [
      "kind": "youtube#channel",
      "etag": "\"gMxXHe-zinKdE9TTEzKu8vjcmDI/q3O415qUconyEsljnEa554j5mM\"",
      "id": "
{CHANNEL_ID}",
      "statistics": {
        "viewCount": "34315",
        "commentCount": "0",
        "subscriberCount": "76",
        "hiddenSubscriberCount": false,
        "videoCount": "74"
I want to import from the above data to VD following information:
viewCount":
videoCount":
I know that the connection to the data is encrypted (via https), so I created a php script and put it on my server:
<?php
$url = fopen( ‚https://www.googleapis.com/youtube/v3/channels?part=statistics&id={CHANNEL_ID}&key={MY_API_KEY}’, ‚r’ );
$wynik = ”;
while (!feof($url)) {
$wynik .= fread($url, 8192);
fclose( $url );
header(‚Content-Type: application/json’);
print_r($wynik);
Then I created of virtual device on the Home Center:
HC2 = Net.FHttp(„ADDRESS_OF_MY_HOSTING”,80);
dane ,status, errorCode = HC2:GET(„/PHPFILE.php”);
ajson=json.decode(dane)
view=ajson.items[1].statistics.viewCount
fibaro:call(195,’setProperty’,’ui.Label1.value’,tostring(view))
video=ajson.items[1].statistics.videoCount
fibaro:call(195,’setProperty’,’ui.Label2.value’,tostring(video))
The problem is that it does not collect any data from YouTube.
In main look I see:
 line 2: unexpected symbol near '�'
If anyone has any idea where I made a mistake or how I can accomplish in a different way?
" to "
Temat został przeniesiony z "
" do "
Try using straight quotes, rather than curly ones - ie:
Below my VD and scene:
MAIN LOOP:
%% autostart
%% properties
%% events
%% globals
local IDYT = fibaro:getSelfId()
local viewCount_YT = fibaro:getGlobalValue("viewCount_YT")
local subCount_YT = fibaro:getGlobalValue("subCount_YT")
local videoCount_YT = fibaro:getGlobalValue("videoCount_YT")
fibaro:call(IDYT, "setProperty", "ui.Label1.value", viewCount_YT)
fibaro:log(viewCount_YT);
fibaro:sleep(1000)
fibaro:call(IDYT, "setProperty", "ui.Label2.value", subCount_YT)
fibaro:log(subCount_YT);
fibaro:sleep(1000)
fibaro:call(IDYT, "setProperty", "ui.Label3.value", videoCount_YT)
fibaro:log(videoCount_YT);
fibaro:sleep(1000)
fibaro:sleep(7200)
fibaro:call(195, "pressButton", "4"); --run the scene
SCENE:
%% autostart
%% properties
%% events
%% globals
if (fibaro:countScenes() > 2) then
  fibaro:abort();
local url = '
function getEfergy(requestUrl, successCallback, errorCallback)
  local http = net.HTTPClient()
  http:request(requestUrl, {
      options = {
        method = 'GET',
        headers = {
      success = successCallback,
      error = errorCallback
getEfergy(url,
          function(response)
            print ('Status: ' .. response.status)
            local decodedEfergy = json.decode(response.data)
            fibaro:setGlobal ('viewCount_YT', (decodedEfergy.items[1].statistics.viewCount))
            print (fibaro:getGlobalValue ('viewCount_YT'))
               fibaro:setGlobal ('subCount_YT', (decodedEfergy.items[1].statistics.subscriberCount))
            print (fibaro:getGlobalValue ('subCount_YT'))
            fibaro:setGlobal ('videoCount_YT', (decodedEfergy.items[1].statistics.videoCount))
            print (fibaro:getGlobalValue ('videoCount_YT'))
            end,
                function(err)
                  print ('error' .. err)
Cytuj
