LG TV Plugin
Hi.
I have a question. I use the LG TV Plugin to control my LG TV from 2014. Everything is working quite good, I can change channels, the volume and more. But it is not possible to switch on or off the TV with the plugin anymore. I know that it worked some time ago. Has anybody an idea??
Regards
7 answers to this question
You cannot turn LG TV on, unfortunately
all LG devices shutdown TCP/IP TV module and after OFF TV doesnot respond on tcp/ip packets
    Ah ok, thanks for the info.
    Regards
    Hi evrybody! I have a question. I use the LG TV Plugin to control my LG TV from 2015 LG 55EG960V. I push button "request authorization key" for request Authorization code from my TV. But Nothing appears on the TV screen :(
    as for me plugin works OK.
    but if you developer you can send to TV IP address this string:
    "<?xml version=\"1.0\" encoding=\"utf-8\"?><auth><type>AuthKeyReq</type></auth>"
    via http POST to "/roap/api/auth" endpoint
    your TV shoud show auth code on TV screen.
    python code
    Edited by 10der
    Russian LG Support declare that household  LG TVs don't support remote control by IP %(
    lol :)
    I do not believe you!
    I doubt that developer from Munich, Germany have Russian TV (ha- ha- ha)
