Switching off staircase light at sunrise
Hi! This is probably a silly question but one I can't figure out - I have two almost identical scenes: one switches on the light at sunset, the other should switch it off at sunrise. The first one works, the latter does not. Both have one instance running. What could be the problem?
I think you need to post a copy of you scenes for any one to help you here:-)
