Homekit app Links to HC2!
The new home kit app links to Home Center - in settings you can now add HC IP address and credentials and devices show along with scenes via home center. Wondering why though? Is it to bridge gap between HomeKit and Zwave devices?
Homekit app is nicer - cleaner - so it seems can use this app now if preferred?
9 answers to this question
Could you share screenshot ...
Guest chaicka
Though able to see the z-wave devices and scenes on HC, there is no function to cross between HomeKit devices and Z-wave devices, nor ability to add new scenes. Looks like it is still very much in development.
    IT actually can load HC devices, only it asks for local access data only so probably no remote access here.
    confirmed - local only no remote
    Takže jde o komunikaci prostřednictvím řídící jednotky že?
    Není to tak že by nám řídící jednotku nahradili výrobky od jablíčkářů.
    posted already here some findings
    Guest chaicka
    Works if connect from outside through Internet to HC2, not when via Fibaro's remote access.
    " to "
    Temat został przeniesiony z "
    " do "
