muppetman74 0
OK, so I have a HCL on 4.105. The heating panel is not working in this version (as documented on this forum), so I decided to set up scenes to schedule the heating and hot water.
The heating and hot water from the boiler are controlled by a Fibaro dual relay (FGS-222) - relay 1 for the heating and relay 2 for the hot water.
Relay 1 is associated with a Secure Thermostat - relay 2 is not associated with any device.
I set up a simple scene to turn my hot water on in the morning for 40 minutes - this works with no problems at all.
I set up another scene to turn the thermostat set point up to 19 degrees in the morning - this doesn't work at all. If I change the setpoint on the Thermostat on the web interface, mobile app or physically on the thermostat, the heating comes on with no issue - and status is being reported correctly within the web interface.
Playing around with this, I found if I set the scene up to directly turn the heating on by using the relay in the scene, the heating comes on as expected. When I change this scene to turn the heating on by changing the setpoint on the thermostat, nothing happens!
I really don't understand why this would be the case - am I missing something simple?
Thanks for reading!
