2 wall plugs in row
Hi.
I need 2 wall plugs in a row. The first one is sitting at the wall and should measure the whole power within HC2. The second one is behind the first one in a power strip and has to switch one user off and on. Problem is that the second one also measure and shows the power. So also the main value of the current is wrong because I have one device which is counted twice.
What I want is that the second wall plug is not showing any power and power used at all. It shall be switched off totally. How can I do this?
Regards
