Volvo On Call VD/Scene
riemers
So i took some time to figure out this whole volvo api thing. I have created a VD/Scene for it. Scene will start up, read the info out and if a button is pressed on the VD it will trigger the scene to do the action.
Since it is my first Scene/VD combo i would like to see if there are people out there with a Volvo that could test it out before i throw it into the wild.
Here is how it looks right now in the VD:
7 answers to this question
  • I've found some small bits that should be better already, and need a place to store the values that are of your volvo id too. I'll do that and i'll upload it here. You can test it, if all goes well i'll place it in the VD section. (that means i will upload it later today, when i finished the removal of the credentials, namely mine.. otherwise you can jumpstart my car haha)
    this is cool! make a  scene were  the heater starts if the temp is below zero and it is a working day!
    i'll test it!
    Edited by emielstroeve
  • Its awaiting approval.. but yes, you can make one then yourself based on your own input (i was typing in this forum, but i thought i can just as well place it there)
    p.s. the temperature, it doesn't get from your car. It just takes your long/latitude of your car and query's a weather api!
    Edited by riemers
  • Waiting on approval..
    Still waiting..
    Edited by riemers
