Lenfors 0
Hello!
This is probably a real newbie problem, but I spent all evening with no luck.
I made a LUA script as below, but NOTHING triggers it by events. I can turn on wathever switch I want or move in front of the motion detectors but nothing triggers.
In the code below I just show the first 11 id:s but I have tested with all my 70 Id:s, and nothing triggers.
I even checked "Do not allow alarm to stop scene while alarm is running" but it does not help.
If I start the script manually it shows the text below, as it should.
[DEBUG] 22:45:13: Other source.
Yes, I restared my HC2!
Please help!?
Best regards, Mikael
%% properties
1
2
3
5
6
7
8
9
10
11
%% globals
local trigger = fibaro:getSourceTrigger()
if (trigger['type'] == 'property') then
fibaro:debug('Source device = ' .. trigger['deviceID'])
elseif (trigger['type'] == 'global') then
fibaro:debug('Global variable source = ' .. trigger['name'])
elseif (trigger['type'] == 'other') then
fibaro:debug('Other source.')
fibaro:call(18, "turnOff") -- Trying to turn of my testlamp on whatever event
4 answers to this question
