Association of two Fibaro Relays not working (anymore)
it seems the "new" possibility of linking devices together does not seem to work in my case.
What I had:
2 Fibaro relay switches, one (A) was associated to the other (B), thus when A got switched, B was also turned on.
I also had a simple scene where, based on a Door-contact, Only B was turned on.
That is not working anymore, so I thought I give the new model a try and marked B in the configuration of A thus they are switched on as one-> working.
However B is now no longer visible or switchable alone! Which means my simple scene where I only switch on B is not working anymore.7
Do you have hints? Did I get something wrong?
cheers
joystick
    ok, nevermind I found out that the device is automatically hidden in the system, thus I need to make it visible again...
