Hello All,
For my work i'm a lot off hours from home. The two hours at home I could better use for my wife :mrgreen:.
At my work A got a lot off time to work on the FHC2. I mean with that; try to get VD working ect. like very smart lights for example.
When i'm online I can't edit/install scenes and VD. I tried to forward a port from my router to the FHC2. That did not work.
Is there any solution for?
kind regards
Kees
I use a VPN to my home router, works fine.
    dankje Emiel.
    when I'm connected to the home network I can connect through VPN. When i connect to my telephone and try VPN :
    the connection is interrupted. caused by VPN transmission probable internet latency or vpn server reached capacity.
    I did woke up! turned on the data connection on my phone. Works fine now. Thanks for the reply.
    kind regards Kees
