Is fibaro:getDevicesId working properly?
Hello.
Im trying to get fibaro:getDevicesId working, but something is not working properly.
Is it me (LUA) or something else?
fibaro:callGroupAction does work.
** Update
Ok so i found a solution from another post, but the structure "data" is different then developer page but it works.
So, there must be an error on the developer page then?
Code to get "getDevicesID" working:
And the post where i found the code.
I got the "getDeviceId" code from directly from developer page. (This code doesn't work)
When i use the same code but use "fibaro:callGroupAction" i get the ID´s from that room as expected.
Edited by speedy
