Torbjorn 6
I'm trying to change a parameter in one z-wave device connected to HCL from my HC2.
If I do it in the REST API in the HCL, everything works OK.
When doing it from the HC2 in a VD with this code:
HCL = Net.FHttp("admin:[email protected]")
jtable = '{"properties":{"parameters":[{"id":34,"size":1,"value":0}]}}'
HCL:PUT("/api/devices/6",jtable)
it does not work....
Is there a limitation in the HCL ?
I have exactly the same code running for the same device in HC2 and there it works
Thanks in advance for your help !
Edited by TorbjornSolved
8 answers to this question
