rsjabbens 1
Hello all,
Can i use a dimmer 2 with a powered toggle switch connected to S1?
I already have a 2x1.5 switch to some light bulbs, one is working with 2 wall switches. In the attached drawing you can see that i want to add a Dimmer 2 (fgd-212) between another light bulb and 2 regular toggle wall switches (number 1 and number 2 in the drawing). Currently the bulb connected to Q2 from the 2x1.5 switch is switched by the left part from wall switch 2 or the right part from wall switch 3. Can i somehow do the same with a dimmer and wall switch 1 and the right part from wall switch 2?
7 answers to this question
