Hi there - i've stupid problem, i'm looking for parameteres in dimmer setting to set up (configure) switch positon - every time im using my phone to turn on light and i switch that light off, My main swich position is up side down. The only way i found to put it back is to do it again, but it must be some other solution, i could't find anything in the setting of dimmers - maybe i'm missing something.
Please help me :(
Rocker or momentary switches?
Edited by Jamie mccrostie
    momentary switches
    When you say main switch position you mean browser device switch position? That should mimic app sw
    But if you are meaning the wall switch if its momentary it cant be upside down.
    i just want my momentary switch to have the same on and off position, as i sad when the light is off and i turn it on from my phone and switch it off from the wall switch, then my wall switch position changes. And if u have a double switch u don't wanna to have one switch up and the other down - both off - that is not nice - a specially for lady's if u know what i mean
    I think you have rocker switches. The only way around this is to replace wall plate with push button momentary switches, which most people use for this very reason.
    and yes i do know what you mean with that :-)
    thanx for your reply and u r right i mixed up switches - that 's binary switch / apology
    Push buttons def the way to go with dimmers, double press on full brightnes etc easy to change over
