Fibaro button not triggering on first press
Hello!
I have a Fibaro "Button" and having problems that it is not firing an event first time it is used for a while.
%% events
22 CentralSceneEvent
This code does not execute when I press the button first time. If I wait some seconds and press it again it works fine.
After this it works without any problems until it is "idle" for some minutes, then it fails first press again!?
Some option to fix this?
Best regards, Mikael
the button displays how are you pressing it via user interface, open that up and see how ti reacts to single button push. (awaken is 4x button pushes i belive)
Assuming you did not aler advanced parameters, there are no associations to the button and you basically use it as it was out of the box (only added it into the scene) woudl you try and reset the button to factory default please?
Thats 5x press button than press and hold for aprox 5 seconds, or you could just remove it from netowrk that'll work too .)
Annyways after you've done that and reincluded it, fixed the device ID within your scene and it still did not work you migth have a problem with it. If you reached here i would suggest contacting [email protected]
