riemers 20
Ok, this is not the best solution and might need a few more tweaks to make it look perfect (but i wasn't going for perfection)
Get Chrome, install the plugin called "Stylish" after you installed it, go to preferences, make a new rule and add your domain name or ip address of your fibaro. Then add the following css code:
Once you done this, at least the lua code window looks like this:
So what this does is change the css code so that it tries to span the full screen that you have. So i assume you have a high resolution monitor or else it might look funny
p.s. found a class that is called ".FisrtHeadline" Nice typo, it is in the html and css..
Added bigger scene lua edit too..
7 answers to this question
