4 switches & 3 lights. How to use 4th spare switch?
I have 3 separate lights in my kitchen, each one controlled by its own dimmer 2 module.
One of the dimmer modules has S2 connected up to the spare (4th) switch.  The switches are all single momentary on/off push switches.
How can I program this 4th switch to turn ALL of the other 3 lights on and off at the same time.  I'm guessing this is doable?
i am using a universal binary sensor for this in my bathroom~
 you can use a momentary switch so you can make different scenes, when you press ones or twice, etc...
Hi @MonkeyJug
I haven't done this but found  this post
I also found a vesternet article here  -
It taks about Using a Fibaro Dimmer 2 S2 Input to trigger Scenes in VERA UI7.
perhaps between both you might be able to get it working ....
    Cheers guys - I'll look into those options...
