VD stopt working
I need some advice here. I'm stuck. :-)
I made a VD to be able to set if I'm home or away. I use the variable 'globalstatehome' with 'Thuis' or 'weg'.
When it is set to away (weg), it should switch on some lights on a certain time before sunfall. A bit before midnight it should switch them out again.
It all worked perfect, but suddenly stopped working. It might have been after an update, but I'm not sure because I don't use this scene and VD verry often.
What could the problem be? It is a HCL, so I do have some limitations. When I use the scene manually, the lights do work.
Here are some pics.
Thanks for helping me out.
" to "
Temat został przeniesiony z "
" do "
Fill there Content-Lenght: xxx. I learned hard way, that it's needed.
xxx is length of JSON body, that begins with { and ending with }. You can see body length of you try to change a global variable with Wireshark running. Also I would recommend some http plugin in browser or API tester from MS Store. I found it quite helpful.
And make sure your JSON body is valid. When I copied JSON body from Notepad, I had problem in quatation marks.
