HI,
i have an outdoor combined Set of an Motion sensor and a LED Lamp. If the Sensor recognize an movement the build in Lamp goes on.
Now i want to know when this happens and have a Signal send to my HC2.
The MS/Lamp Combo is permanent on electricity (230V) but i guess only the Motion Sensor (Lamp off) comsumes little. When it detects movements and the Lamp goes on it must consume much more.
What I am looking for? Watt or Ampere increase.
What Fibaro Module can i use for this Situation? Dimmer 2 or the Relais?
FGS measuring ability: W and Wh, same is true for FGD.
Neither measure Ampere separate so for your needs might be easier to just use relay switch and count Amperage separatly:
there are other ways offcourse
but the Watt/Volt = Amper seems fairly strighforward.
