Momentary Button VS Button's Application
Hi folks,
I just joint this forum, So please apologies if i repeat same case that already discussed before.
I have dozen of FGD212, some of them connected with more that one dimmer LED led ( in parallel ) with trailing edge dimming protocol from phillips ,  turn on/off or dimming from mementary switch  work flawlessly, but if from button or slider at application , needed to click or slide several times before the lamp "on", after "on"  next click  work perfectly. Thats onlu happen at first click
anyone has same experience and solution ?
