Lately I have problem that the web interface is so slow.
I happened the after an update of the wifi router. There is no other equipment in the house that have changed it only the HCL.
The same time the wifi router was updated Fibaro changed the logon to logon ID.
So it is not easy to understand what realy is the problem.
What browser are you using?
I found that MS Edge is very stable and pretty fast in terms of working with Fibaro via web interface. Also my Firefox browser (version 52 i guess) is slover in loading of Fibaro, even with cleared cache memory. Same goes for Chrome. And opera, that i did not tested yet, since only very small amount of users use it.
Hey , try Internet Explorer or Edge is faster then Chrome and Mozila.
Welcome!!! ;D
    The problem must have come from at relay that have flooded the notification center. A Everspring On / Off Switch sends a message: [Power has been applied] several times an hour. I made a scene that deletes the notification center once an hour. The problem slowed, the HCL i responding perfectly.
