Association with qubino flush dimmer 1-10v
Hello there,
I was pushed to use dali transformers with my HC2. I've used qubino flush dimmer 1-10v. Everything works well. Now I'm facing a problem. There is LED spot powered by dali transformer and 230v lamp which should dim together by one push button. The push switch is connected into qubino and for 230v lamp I use fibaro dimmer 2. There is no possibility to connect them together by wires, because qubino is powered by 24VDC.
How to set the associations that synchronize both dimmers? I already play with that a long time, but no success.
There is a primitive drawing in attachment.
" to "
Temat został przeniesiony z "
" do "
