Hi.
I am a hobbyist beginner. I have a gas boiler Junkers ZWE 24-4 MFK (manual available at:
 ). By default, the proprietary thermostat uses an analog three wire that feeds different voltages 2,8 - 24 V DC.
I learned that there is a jumper in the boiler's terminal block between Ls-LR that when removed causes the heating to stop without turning off the whole machine. It is therefore a place to plug in an on/off thermostat. As a hobby project I want to use a fibaro module that I will then code with raspberry to open/close depending on the temperature in another room.
Could someone please review if the scheme below is a proper way to plug in a Fibaro single switch FGS-213?
14 hours ago, morscerta said:
Hi.
Yes this will work
Get the fgs 212 or 222 relay instead of the switch 2 for this then if 'LS' is switched by some other function in the controller
the fibaro relay wont go off line
You can feed the unconnected L off the incoming supply and then just switch your LS and LR thru the contacts.
Just make sure its all the same voltage L and LS, which it looks like it is, other wise you will need another seperate relay for safety seperation.
Edited by Jamie mccrostie
