@AutoFrank....to stop false activation after a power cut or other issue, try this. It's been working great for me.
You effectively just totally disable the actual switch in the system and us a VD to enable/disable it.
Arm Button
Disarm Button
Scene to Operate Door
Edited by Desmo
Arm Button
Disarm Button
@Desmo, thanks for that. If combine it wither a way to detect power coming back on, it might do the trick. I also now wonder could it be caused because I am using a FGS212 as a zero volt relay. if the inrush of current to the device when the power comes back on was momentarily impact the IN-L1 isolation then this could be triggering the door to open, Two avenues to pursue but I  think I may have other used for your code above.. thanks for sharing..
I'm not sure what your issue might be to be honest...I'm using a Qubino dry contact relay which is perfect for this type of thing. I had a couple of false operations that I could never track down what actually caused them so thought of disabling the device in the system until it was actually needed.
@AutoFrankI fell into this trap with the pump vd you helped me with a month ago.. power cut causes pump fault.... also cuts power to fgs looking for pump fault ... which goes back to pre powercut setting after power comes back on
Edited by Jamie mccrostie
