Help for iCloud Calendar integration via cronofy
Hi all,
I have been inspired by the
 and found a way to do the same with iCloud calendars via cronofy.
So I wrote a small Lua Script, that basically connects to the cronofy api to my icloud calender an reads the events as json table.
This is actually working, but I am stuck here, because I am not really developer,
Could someone help me getting the event data out of the data pile I recieve and store it in a reasonable way?
I would like to achieve the following (e,G.):" If there is a event named "bla" then turn off the alarm etc" (via VD or scene)
cheers., and thank you guys in advance!
joystick
Edited by Joystick
" to "
Temat został przeniesiony z "
" do "
