Marti 0
I made the following scene in LUA (to start ventilation when CO2 level is getting high and to stop it when it has gone back down). See code below.
It uses Netatmo device for CO2 reading (polling frequency 10 minutes).
I noticed that the scene is acting strangely - every 10 minutes (the time the new CO2 reading arrives from Device 24), the fans (devices 40 and 42) are switched on very briefly, for 1...3 seconds, and then back off.
CO2 reading has all the time I'm testing been around 600, so well below the threshold levels.
What can cause this anomaly?
%% autostart
%% properties
24 value
%% weather
%% events
%% globals
if (
( tonumber(fibaro:getValue(24, "value")) > 900 )
or
then
fibaro:call(40, "turnOn");
fibaro:call(42, "turnOn");
else if (
( tonumber(fibaro:getValue(24, "value")) <= 800 )
or
then
fibaro:call(40, "turnOff");
fibaro:call(42, "turnOff");
5 answers to this question
