[Survey] My Network 4.112 update survey part 2
My Network
  1. 1. My HC2. Please only fill if you answered "I upgraded with no issues " in 1 of the main survey Tick all that appply
    • Less then or equal to 30 Nodes
      0
    • Between 31 and 60 Nodes
      0
    • Between 61 and 90 Nodes
      0
    • Between 91 and 120 Nodes
      0
    • Between 121 and 150 Nodes
      0
    • 151 or more
      0
    • I have to move some nodes closer to HC2 to reliably soft/hard reconfigure
      0
    • I have to move nodes closer to HC2 to install new firmware updates
      0
    • I have used a fibaro device with ZWave check function and it communicates via routing in many locations
      0
    • I had serious issues prior to trying upgrade. Dead nodes - Restarts - High CPU usage.
      0
  2. 2. My HC2. Please only fill if you did not answer "I upgraded with no issues " in 1 of the main survey Tick all that appply
      0
      0
      0
      0
      0
    • 151 or more
      0
      0
      0
      0
      0
The final questions for the Poll to describe your network
Edited by robmac
Added that the topic is about the survey.
As you created another survey, I have to move this one to Community Support as it does not relate to the update.
" to "
Temat został przeniesiony z "
" do "
    This is part of the survey for 4.112. Please put it back
    Was in two parts due to limit on number of questions
    Edited by robmac
