Aeon Multisensor Gen5 - Motion Sensor
Hi all
I have recently bought the Aeon Multisensor (Gen 5) and can't get the motion sensor to work. Once added, I get the temperature and lux being reported but the PIR doesn't seem to work.
Have any of you got the same issues?
Tested on 4.111 and 4.112 Betas
Edited by mrtn
8 answers to this question
14 minutes ago, mrtn said:
Hi all
Hi @mrtn
If it is the Multisensor6 (square one as opposed to round one)
I had a lot of problems getting these to include with all slaves (lux, temp, humidifty, etc)
See thread here for discussion -
for me there was no silver bullet except patience (lots of ) and time
The only silver lining for me that when one did include correctly, it seemed to work fine from there
-f
    Hi @AutoFrank
    It's actually the round one... (previous version)
    I've already got the square one which works okay but I am not entirely happy with its PIR's sensitivity so wanted to give the earlier model a go.
    2 minutes ago, mrtn said:
    Hi @AutoFrank
    @mrtn
    Sorry :-( can't help you with one
    Hi i ve thesame problem with thesame sensor - still didn't figure out what is wrong with it - so i send to aeon to check it out
    Hi @mrtn and @confesor,
    please check bellow link:
    This sensor is without template and Fibaro will not make one, but some of the parameters can be added manually and then it seems to work. I haven't check yet with mine.
    Before adding parameters on advanced tab of the sensor remove tick for Use template for parameters then press save button and make sure that you wake up sensor. Then add parameters manually press again save button and then wake up sensor. That should do the trick.
    Hi @Sankotronic
    Thanks for the info. I gave up on mine and sent it back - good old Amazon :-D
    These settings work for me, and all the sensors  (Lux, Motion, Humidity & Temp) report. Give the a try
    i have 1 old Aeotec multisensor gen 5 and i want to check its temp but temperatur doesnt show temperature, please give me desired setting if manually add parameter needed then guide me.
