I have two Vitrum switches in each end of the house. I want to control the same dimmer from each of the Vitrum switches. That's impossible right now. When I associate one Vitrum button to the dimmer I can't set the other button on the other switch to the same dimmer. Because the dimmer is gone in the first association. Can you please fix that? Must be a simple way to do for Fibaro.
I can't be the only one with this problem and request?
Regards from Sweden...
Edited by DjHedan
  • 2 months later...
Why do not you try to assocciate the vitrum dimmer to the other vitrum dimmer and then the second vitrum dimmer to the fibaro's dimmer? Is it going to work that way? It is worth trying though. It is easier to do the same with relays and scenes but they are on/off. You have in your case dimmers...
  • 1 year later...
Just a flashback to Vitrum and Fibaro....I can't find a way to expose  my dissapointment with Fibaro team.... :(
One of our very important clients bought Vitrum switches (around 15 pieces - mostly 6 buttons) as a addition to his newly renovated appartment. He already had HC2 with a lot of features and devices. My team was selected as a installer team. We did installation and all went fine. But then problems started to jump in with Vitrum and Fibaro.
We sent numerous of emails to Fibaro and Vitrum support and I have to say, guys from Vitrum were very nice and tried to help but stuck. It was found that issue is probably on Fibaro side, so we tried to get deeper into problems with Fibaro technical support and here is such a nice answer: "WE HAVE NO 100% WORKING SOLUTION HERE, NOR WE WILL CONTINUE TO SEARCH FOR ONE. MY ADVICE IS TO USE FIBARO SWITCHES INSTEAD OR TRY TO GET WITH THE VITRUM SUPPORT!"
If anyone here have ANY WORKING solution here, please reply or send me a message. Fibaro is not willing to support their clients so be careful.
