How to make a scene to centralize a function
This technique can be used for a lot more but this simple case illustrates it in a very simple way.
I am not seeing a lot of example of using this feature posted so I thought this might give  a few who do not know some ideas. The technique is based around that second parameter of the fibaro:startScene method fibaro:startScene(sceneID,args).
args is a LUA table so you can pass pretty much anything to a scene via the API or from another piece of LUA. In this example only a table with one text element is passed.
Create a scene myDebugIllustration
You may need to set the number of instances to a larger number wen you use this properly.
Now create another scene myTestScene
Now remember that as I said earlier "a lua table can hold pretty much anything"
Enjoy
23 minutes ago, szmyk said:
Is it possible to pass to a scene special characters like ä,ö,ü, ł, ó, ą ?
Actually I get different chararacters: ÄÅÄÅÅ
Hi @szmyk,
I tested with @AutoFrank SMsgH scene and find out that it is not possible to pass special characters to scene. That is big disadvantage for this feature.
I need it to SMsgH, too :(
Maybe base64 would help but there is no native base64 function in fibaro api.
I was trying urlencode function, but there is no native urldecode function.
@szmyk, @Sankotronic
Maybe its time to bring back the SMsgH v 1.0
It was invoked with a global variable change and not startScene and hence didn't suffer from the international characters issue
There were other change with 1.1 but perhaps we could have 2 versions available
it's not ideal but perhaps its the best solution for now....
@AutoFrank
Have you tested parallel invocation of SMsgH with global variable? Are there any problems?
StartScene can be run parallel 10 times (after setting scene parameter).
@szmyk, I wouldn't think so as only one global is used and that needs to be overwritten so I would assume it's serial flow...I haven't come across a situation where I need to send message that rapidly. If I have parallel requirements, I usually try and space them out by 500ms
@AutoFrank
I have not many scenes and VDs so it's not a big problem for me. But for person who have huge installation like you or @Sankotronic it could be a problem. Two or more scenes or VDs may want to send message at the same time. It's not possible ro run them sequentially because they are independent.
Edited by szmyk
I've found a workaround and described in this post:
