Is the graphical scene editor buggy
I'm new to HC2, but I do have a software background. Trying to turn off a light after 5 mins of no motion. The generated Lua code seems way to complex, is there something wrong with this?
Device ID 48 = Fibaro motion sensor
Device ID 39 = Fibaro dimmer
Thanks!
" to "
Temat został przeniesiony z "
" do "
This is Lua code:
%% properties
48 value
%% events
%% globals
if (fibaro:countScenes() > 1 ) then
      fibaro:debug("Stop")
    fibaro:abort()
local id=48 --Fibaro motion sensor.
local id_relayswitch=80 --Fibaro relay 2 switch.
local id_status={25} --If id 25 (Fibaro relay2 switch) ON, the scene will not run.
local status=tonumber(fibaro:getValue(id, "value"))
local currentDate = os.date("%H:%M");
local begin=0
if status>0 then
  if currentDate> "22:30" or currentDate < "06:00" then --Run from 22:30pm to 06:00am
    for var=1,#id_status do
           local bien=tonumber(fibaro:getValue(id_status[var], "value"))
          if bien>0 then
            begin=1
    if begin==0 then
      fibaro:call(id_relayswitch, "turnOn")
      fibaro:sleep(1*60*1000) --On light 60s
      fibaro:call(id_relayswitch, "turnOff")
Edited by signhathongminh
