Vitrual device HTTP command
Hi
How can I send http command to device using virtual device in HCL to http://user:pass@IP/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=8/1/7&value=true
Is there any documentation or manual about integration of HCL/HC2 and http?
Thanks in advance! :)
5 answers to this question
Hi
Perhaps you can use this link.
Edited by hTiger1
    Thanks for the replay. The links are very useful. But I still can not control device. May be miss something. I try to encode username and password and replace in example but nothing happened when I press the button on HCL.
    Please can you generate the string for me? url is:
    http://remote:[email protected]/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=8/1/7&value=true
    Edited by Desislav
    Hi
    Do you generate username: password
    Yes, thisi is the result cmVtb3RlOiByZW1vdGU=
    But not working.
    Hi
    VD to automatically restart I use HCL's ip address: xx.xx.x.xx and port 80
    VD for Heating / AC panel holiday mode and Camera I use the IP address: 127.0.0.1 and TCP port: 11111
    It is very important that there are space where there should be a space and vice versa.:-)
    Whether you should use the "Get" "Put" or "Post" I do not know, but try different.:-)
    Edited by hTiger1
