change a VD's label with PUT
In   FIBARO FGHC REST API ACTIVE DOCUMENTATION   I tried to change the value of a VD's label (Ltest) with PUT.
The body
  "properties": {
    "ui.Ltest.value": "XY"
doesn't succeed:
Response Body is "no content"
Response Code is 403
Which body has to be used?
today new attempt (as superuser):
with body
{"properties":{"ui.Ltest.value":"YYYYYX"}
I get
   Response Code  200
   Response Body: complete body (like GET)
   but VD's value has NOT changed !!
Somebody knows a solution?
Background: my raspberry can change a global variable simply by sending {"value":"new value"},
now it should change a VD's label ...
Edited by muc
new attempt
How do you change the global variable from raspberry?
    with node.js like this
    var http= require("http")
    var daten= ...
    var gvDaten= {}
    gvDaten.value= daten      or    = JSON.stringify(daten)
    var datGV= JSON.stringify(gvDaten)
    var optGV= {
      hostname: 'HC2_IP',
      port: 80,
      path: '/api/globalVariables/Global_Var_Name',
      method: 'PUT',
      auth: 'your_IP_adr:your_PW',   //  superuser's  hc2-login
      headers: {
        'Content-Type': 'application/json',
        'Content-Length': Buffer.byteLength(datGV)
    var req = http.request(optGV, function(res){
      console.log(res.statusCode);
      res.setEncoding('utf8')
      var antw= ""
      res.on('data', function(chunk) { antw += chunk })
      res.on('end', function() {
        console.log(antw)
    req.on('error', function(e) {
      console.log("problem:"+e.message);
    req.write(datGV)
    req.end()
    great surprise:
    a scene with
    %% globals
    Global_Var_Name
    is NOT started
    ( it can be started by a POST request inside res.on('end', function(){ ... } )
    Edited by muc
    hostname: not Raspi_IP but HC2_IP
    just found:
    a scene with
    %% globals
    Global_Var_Name
    will start when
    {"value":"1234567890","invokeScenes":true}
    is sent
