Dear all,
In our bedroom we have installed a Fibaro dimmer module for the main lights. On each side of the bed we have installed another dimmer that is associated with the main light dimmer. Essentially this works fine except for a 10s delay before anything happens when pressing the bedside dimmers. Do you have any clue what can be wrong here?
Thanks!
8 hours ago, 3JL said:
Dear all,
Thanks!
Have you tried a  soft reconfigure of devices. Then if no better exclude , Reset and reinclude.
Im guessing here but thats where I'd try. I have a similar set up at home which works with a slight delay but not 10 seconds.
I have one dimmer thats a bit slow when remote on off dim, so  as a last resort in case the main dimmer is a dud try changing main dimmer with one of the bed side ones and see if it makes a diffenence.
Edited by Jamie mccrostie
10 hours ago, 3JL said:
Dear all,
Thanks!
I guess it you could do a range test on the dimmers too
