I have a number of devices that I only ever use locally in my house. Just now both apps want to connect remotely and fail as I have not set them up to do that. Please can we have an option the makes the device work in a local only mode and never try a remote session.
Robert
Robert
I trying to solve it too. Our salesman has case with Fibaro model.
Fibaro support told me to add that gateway to Fibaro ID, even if it never comes online. I need to test this "theory", hopefully this week i can test it.
For some reason, it work when you turn off Mobile data (3G/LTE).
Just an addition.
With just LAN (excluded from internet) it worked fine before Fibaro ID came up.
  • 7 months later...
I run mostly over VPN on the ipad and phone, Would that achieve the same result you are looking for @robmac ?
Cheers,
al.
    Hi Al,  That does work for me and I use vpn but you still get the fail on the app as it tries to get remote access.
