metal121 0
So, I went and bought a Carrier Cor wifi thermostat for $350 because the HC2 has a plug-in for Carrier Furnace thermostats. I have the new thermostat up and running and I am now trying to get my HC2 to connect to it. In my HC2,
1. I have the Carrier Furnace plug-in installed
2. In the Carrier plug-in, under "advanced", then "network configuration", then "IP address", I hit search.
3. The plug-in can't find the ip address for the thermostat and says nothing is found
3. I have tried to input the IP address myself into the "IP Address" box and it still says it can't find the thermostat
The thermostat is working normally, has an IP address and a MAC address, no problems with it.
Any one have any idea how to get this to work or did I just waste $350 dollars???
Thanks!
