Virtual device or plugin for weather help
Hi.
I have HC2. Recently I bought weather station (semi pro), and I manage to send data to HC2 (using http PUT - fill global variables). Now I have all data in global variables and my question is how to combine all global variables (temp, humid, wind speed, wind direction, gust speed, pressure) in one Virtual device, or use some plugin. Also I wont this data to be main for weather provider in general tab. Please help.
There are two was you can achieve this,
First build your Virtual device with all the labels you require.
Then use the LUA main loop in the virtual device or you can use a auto scena to update your labels.
If you need help with LUA code. give me your global names and I will build you a basic Virtual device to start you of.
Attached is what I use as example.
Bok @Veki,
You can use this code to update weather data on web GUI interface and applications:
ConditionCode is code that is setting weather icon. I use
 to get weather condition code and bellow table to convert weather code received from openweather to HC weather condition codes:
Upper table is for day time and lower for hight time. Hope this will help.
