localProtectionState json
Hello:-)
Bonjour
The following code passes: localProtectionState from 0 to 2
le code suivant passe : localProtectionState de 0 à 2
local deviceID=547
local json = api.get("/devices/" ..deviceID)
json.properties.localProtectionState = 2
api.put("/devices/" ..deviceID, json)
To fully validate the update, I am obliged to go into the parameters of the FGRM and click on the floppy disk:-(
mai il y un problème, pour valider le changement il faut aller dans les paramètres du module et cliqué sur la disquette
That miss has my code ?
Thanks for help
9 answers to this question
HI @971jmd3
Welcome to the forum.
Could you expand a little more on context, what you are trying to achieve and what problem you have encountered
-f
    salut
    I wish to deactivate the wall controls of my roller shutters.
    By
    With the following code :
    local deviceID=547
    /monthly_2017_04/58e2a595f2e8a_controlfgrm3.JPG.b7611fcd363bd15f5fd42853998d86c3.JPG" alt="58e2a595f2e8a_controlfgrm3.JPG.b7611fcd363bd15f5fd42853998d86c3.JPG" />
    ----------------No operation possible----------------------
    local deviceID=547
    ----------------Unprotected---------------------
    local deviceID=547
    json.properties.localProtectionState = 0
    On 4/3/2017 at 9:09 AM, 971jmd3 said:
    Hello:)
    Bonjour
    local deviceID=547
    To fully validate the update, I am obliged to go into the parameters of the FGRM and click on the floppy disk:(
    Thanks for help
    hi @971jmd3,
    You can using my virtual Device.
    You need change HC2 user and password, ID of the roller shutter and status Protection
    Edited by annhan91
    hello
    Thank you, :)
    but I have error
    9 hours ago, 971jmd3 said:
    hello
    Thank you, :)
    but I have error
    Hi @971jmd3,
    It wasn't the code fault. it is just my debug
    salut
    Unprotected=0
    No_remoteControl=0
    No_operation_possible=0
    What is the correct configuration to lock the shutter
    7 hours ago, 971jmd3 said:
    salut
    Unprotected=0
    No_remoteControl=0
    you try change:
    change(USER,PASSWORD, ID_DEVICE, Status_Lock1, Status_LOck2)
    With Status_LOck_1 number is 0 or 1
    Status_Lock2 number is 0 or 2
    hello
    Whatever combination is always the same
    [DEBUG] 23:45:37: {"args":[0,0]}
    [DEBUG] 23:45:37: Sended 14 content bytes with result [0].
