Hello everybody, anybody know how make this?
Thanks Very Much for any help.
Hi @Rafael Suarez,
First you need to find online web service that offers ordering food or calling a taxi. Then you need to find out what is procedure to order. Simplest way is if it is possible to order using e-mail or some kind of API. When you find out that then it needs to be programmed in HC to send e-mail or order using API calls when button is pressed.
So, yes it is possible but it is not trivial!! Fibaro marketing is known to advertise like everything is easy as a pie, but reality is that many things are possible but not that easy to achieve. If they could just enable user developed plugins then everything would be actually much easier for everyone.
    Hello, thanks for answering.
    You are right and the worst is that the company for which I work put that image in instragram and now I have people interested in that service. I'll see what I do to create something that looks like it.
    thanks again.
    This solution is possible but it entirely depends on the features offered by the services and goods providers.
    There is a note about this on The Button's website.
