Im trying to use a the wall switch to override my sensor scene
I've got a scene running that if the sensor is breached the light will turn on and then turn off after a period of time.
I would like to use the wall switch to override the scene to stop the light from turning off
The problem is the sensor picks you up before you can switch the light on so wrighting a condition that the light must be off before the scene can run doesn't work
Is there any way to make this work?
Can you do something with this scene?
%% autostart
%% properties
896 value
%% globals
-- Autolights created by Trash of Poland on 01-2016
-- Altered by TRicky on 02-2017
-- Motion sensor turns the light on for 2 minutes.
-- Any movement while light(s) on sets the counter back to 2 minutes.
-- No movement during 2 minutes shuts down the light(s).
local Counter = 1;              -- Counter
local TimeLightOn = 2*60;       -- Time to keep the Light(s) On. Change to you like.
local TimeLastMotion;           -- Time when last motion sensored
local MotionSensorID = 896;     -- Motion Sensor
local ControlledLightID = 2205;  -- Controlled Light(s)
local Dimlevel;                 -- Actual dimming level, depending on the TimeOfDay
local DimLevelZero = 0;         -- Putting the light(s) out; dimmed to 0%
local DimLevelLow = 20;         -- Light(s) dimmed to 20%
local DimLevelHigh = 60;        -- Light(s) dimmed to 60%
local DayTime = fibaro:getGlobalValue("TimeOfDay");  -- Global Variable
function AutoLight()
  local CurrentTime = os.time();
  TimeLastMotion = fibaro:getModificationTime(MotionSensorID, "value");
  fibaro:debug("Light Counter: " .. Counter);
  Counter=Counter+1;
  fibaro:debug("Time since last detected movement: " .. CurrentTime - TimeLastMotion .. " seconds.");
  if ( (CurrentTime - TimeLastMotion) <= TimeLightOn ) then
    setTimeout(AutoLight, 10000);
  else
    fibaro:call(ControlledLightID, "setValue", DimLevelZero);
    fibaro:debug('Ending Scene Light(s) Hal Midden');
    fibaro:debug('Putting light(s) out at '.. DimLevelZero ..'%');
fibaro:debug('Starting Scene Lights Hal Midden');
if ( fibaro.countScenes() == 1 ) then
  if ( ( tonumber(fibaro:getValue(MotionSensorID, "value")) > 0 ) or startSource["type"] == "other" )
    then
      if (DayTime=="Dawn" or DayTime=="Night" or DayTime=="Dusk") then DimLevel = DimLevelLow
      elseif (DayTime=="Evening") then DimLevel = DimLevelHigh
      else
        fibaro:debug("Motion detected but scene aborted because it's " ..DayTime)
        fibaro:abort ();
      fibaro:call(ControlledLightID, "setValue", DimLevel);
      fibaro:debug("Light(s) On, Current Dim Level is: "..DimLevel.."%");
      AutoLight();
else
  fibaro:debug("Current amount of running scene’s: " .. fibaro.countScenes());
