Hi, I Have a question is that Possible to make a scene with my Keyfob, wenn i Push the "+" Button make one degrees up at my heating and push the "-" button one degrees down ??
i have no Idea
tnx
ADMIN NOTE:
Where is the solution you provide? Read descriptions of forums before you post.
Edited by T.Konopka
Wrong forum!
" to "
Temat został przeniesiony z "
" do "
Yes. Just create a block scene and select your keyfob device from the Devices-> section. You should see a screen similar to the following. Just select the button number that you want to assign an action and do what ever you want.
