VD cloning a real z-wave module
Dear all,
I am in need for a solution, which I hope I can realize by using virtual devices, but I am not sure whether this is possible and any other alternative solution would be good too.
I have a Qubino Z-wave 0-10v dimmer module (Fibaro should make these too..) in my house's central ventilation system. When I included the module into my network, my HC2 ofcourse wanted me to bind it to a room.
However, I need to be able to show the controls for this module in several rooms. Is there any way to clone this using a VD or something? Ideally something that updates the real device and also checks the real device periodically to see for the latest value so that the shown values for the VD is up to date?
I hope this kind of explains what I am looking for :) thanks!
ADMIN NOTE:
Where is the solution you provide? Read descriptions of forums before you post.
Edited by T.Konopka
Wrong forum!
" to "
Temat został przeniesiony z "
" do "
