Hi.
I'm using ZCH5010 light switches throughout the house.
Having the "indicator set" command would greatly improve their usability. For instance, settings indicator 4 on when the garage door is breached.
What is planned regarding the indicator commands?
I apologize but I do not entirely understand your suggestion. Please, elaborate on this.
    Hi :)
    The front panel of the light switches has four indicators (leds), which can be controlled by the indicator set class (i'm guessing some default z-wave function). Logicsoft controllers, homeseer and vera devices seem to have this functionality. Using an indicator set command in a scene would make it possible to turn on the LED if the garage door is open, and when pressing the lid switch, it will close.
    For further info, look here:
    on page 7: (bad formatting, sorry)
    Indicator Command Class
    It is possible to control the LED in each logical device by means of sending
    Indicator Set
    commands with the requested level
    to each of the logical devices
    . Level 0 turns off the
    LED
    and
    levels
    in the range of
    1
    100
    gives the percentage of LED
    brightness. If
    only the Indicator
    Command Class must control a LED
    , then
    the
    LED handling
    in
    each of the logical
    device
    s,
    can
    be
    disabled
    by means of configuration parameters #3
    #6.
    Edited by lurendrejer
